Interior Pics
384
i wanna see those interiors.....
heres my Flareside without the Realtree Seat covers and with out the sub.
with the seat covers like it normally is. sub and all.
dam you taylor. you have a factory tach. neither of my trucks do. im gonna end up getting aftermarket tach for my Flareside. i doubt the 88 Ann probably wont want one.
My Bronco has the XLT preferred package 648A (The highest XLT package) it has all but a select few options.
384
this is what i got....
VIN: 1FTDF15H5JNA54824
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: UNITED STATES
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: D
Brake System: STANDARD
GVWR Class:
GVWR Range: 0 - 6,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: F15
Vehicle Line: F-150
Vehicle Type: Truck
Engine Type - 8th Position
VIN Code: H
Engine: 5.8 L
Cylinders: 8
Fuel: Gasoline
Engine Manufacturer: FORD
Model Year - 10th Position
VIN Code: J
Model Year: 1988
Assembly Plant - 11th Position
VIN Code: N
Assembly Plant: NORFOLK, VIRGINIA
Production Sequence Number - 12th - 17th
VIN Code: A54824
Prod Sequence Number A54824
Additional Information
Wheel Axles Wheelbase 250.0
Just look at the pan, if you have an OD off button u might have an E4OD. I got the AOT, and thats what your bronk got too.
its a 351W HO and C6 out of a 84 F150. theyve been swapped in and converted to EFI.
Sorry I meant AOD. On another note I was watching the local news, there were doing a story on the proposition of a "Wheel tax" (20 dollars on each car) to raise tax revenue. First they showed a beat up Gen. 9 F-150 then a Gen. 8 Bronco with the exact same color scheme as mine.
Lol na my trans in my bronk is a AOT, its the same as an AOD, but it takes a different filter, if you look it up in the parts book, its AOT/AOD
