Inaugural compound and polish!
SFssft1911
North Carolina Chapter member
559
2
Nicely done.
Tell me more about how you guys did it.
Do you use the quick spray wax, then rub the bar over it? The bar really hangs on a dry surface so I assume that's the purpose. It took an insanely long amount of time to do my old truck a few years back.
I didn't find the clay bar to take any longer than a typical wax. I spray the Kwik detailer for a little lube...then I rub the bar over the sprayed are with a little force. I go in 'strips' across the area, always going the same direction. Then I give another Kwik spritz and buff out the section. Then wax...then a coat of polish.
Nicely done.
Thanks!
Ben hit the nail on the head. I usually skip the polish step because a clay is mostly all I need to be content. So, to recap, quik detailer sprayed on the cool surface to lubricate the clay. Run clay over surface, periodically kneading it to reveal clean clay. Wipe the area clean with a good microfiber cloth after finishing the section. Spray wax on top and done!
