Removed and replaced upper and lower BJs on Passenger side. 1989 F150 4X5, 4.9 233K. Used Moog 2 times in the past and no problems. Good stuff. This time I tried Auto Zone brand since I rented/bought the spanner wrench from them. Had NTB press joints in, not too impressed. Re installed knuckle and lower joint stud spins but won't tighten Tried cleaning lower stud and arm hole with alcohol along with a jack under the knuckle. Got it down resonably far, but it still is not tight and has play. I was thinking about putting some thin metal in there to tighten the stud. Bad idea? Disimillar metals corrosion, alignment issues, failure of metal filler? The other thought was to put three or 4 evenly spaced dimples or longitudinal lines on the stud with a punch or cold chissle. The slightly displaced metal should be enough to "bite"? Good idea or Felony stupid?
Oh yeah... I no longer have a dust cover, I now have a rusted "dust" ring hiding under the spindle/knuckle joint. Ideas? Also the dealer no longer carries the 14mm bolts holding the spindle to the knuckle. Seals from the dealer?? LOL The bolts I have are still useable, but I like to replace parts just in case I may need to revisit this in the future.
The sector seal is next. Pittman arm is already off. Doesn't look like fun
Thanks for your thoughts, Joe
I LOVE my mostly blue extened cab 8ft bed.
