i got a little question abt my 351w
fordman76367
Texas Chapter member
426
4
ok... i just bought a edelbrock performer series 600cfm carb for my 84 f150 and online the carb description at edelbrock.com says that it should be matched w performer and performer EPS manifolds and it says not to put it on a torker 2 or a RPM manifold...would i be able to use my stock manifold?
surewhynot
Rep whores make me sick
13,843
821
Florida
Yes you can use it on a stock 4 brl intake manifold.You may have to use a small spacer under the carb if there are clearance issues between the throttle linkage and the manifold.
fordman76367
426
4
thanks ill keep that in mind...it shouldnt rob any performance or mileage will it
fordman76367
426
4
yea the factory 4bbl double pumper w cali. ignition
surewhynot
13,843
821
Florida
You will probably get the same mileage and maybe a tad better power. If your carb is wore out, you might see an increase in mileage.
fordman76367
426
4
thanks..hopefully ill get a lil more power hopefully 25 to 30 hp or more\
surewhynot
13,843
821
Florida
I wouldn't expect that much of a power increase unless your current carb is completely shot.
fordman76367
426
4
actually it is the stock carb is a piece of crap
