how to tell the difference?
loudandlifted
bleeds oval blue
198
camdenton mo
visually how can ya tell the different between a 351 and a 302?
1,320
82
The 351W is physically larger than a 302... Taller deck height and wider intake manifold...
Another way to tell is by looking at the distributor hold down. If the hold down is flush with the bottom of the intake manifold, its a 302, if the bottom of the intake manifold sits about 1" above the hold down, it's a 351W. I have a picture if need be.
Another way is to look at the water pump area in comparison to the heads. The heads are right against the waterpump casting on a 302, while there is about 1" between the water pump and the head on a 351.
loudandlifted
bleeds oval blue
198
camdenton mo
hey eagle would you mind postin a pic?
