How to tell D60 from D44hd
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
Im startin to look for a D60 front for my truck and want to know whats different between the two and how to tell em apart. I know about the castings and where to look for em but what else will help me figure out whats what.
TexasNomad
FTFS Designated DRINKER!
2HI2CU
North Carolina Chapter member
127
4
NC
In the 70's the 60 will have king pins,while the 44 was ball joints.
What you want is a high pinion king pinned 60 with open knuckles.
Another quick tip is...a D60 diff cover bolt accepts a 9/16" wrench and a D44 accepts a 1/4" wrench. Also don't be confused by the LPD60 and the HPD60. I believe the LP was only in 77 (may have also been 76). The LPD60 is only slightly stronger than the HD44 and pales in comparison to the HPD60 due to spindle count and dshaft entry.
What year is the 60 from in the pics?
My guess would be from a 78 Snofighter or 79. They are a direct swap...you can get a later model D60, but it'll take a few mods to make it fit properly. If I were you, I'd contact Ed (75F350), he'll tell you anything and everything you need to know about an axle swap.
1985 Ford F-150
7,816
307
Tooele, Utah
I saw the sway bar and figured it was from an 80s or 90s 350. Therve been a few trucks in the local classifieds that said they had a d60 in em they were 79s but they didnt have pictures thats the main reason I wanted to know how to tell em apart. They were for upwards of 1000 though so it might have to wait till I really need it.
Well $1000 for a '79 HPD60 is a pretty fair price. I've seen them go for as low as $600(but needed a rebuild) and as high as $1800(with the right gear ratio and built). But good solid axle that you can swap right into your truck with no worries will more often than not go in the $800-1200 range.
