how to remove frame rivets??
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
we tried grinding it but it just wont come out.. any ideas?
TexasNomad
FTFS Designated DRINKER!
Grind then drill out :)
89frankenford
Grabber Green Consultant
4,547
147
NH
yup thats about it. grind them down, if that doesnt work then drill them out or a combo of both. they will come out sooner or later
89frankenford
4,547
147
NH
haha it can be luke warm if you want it to. basically a cold chisel is for forming "cold" metal. as opposed to chisels that are used to form hot metal or if you were using a torch and a chisel.these chisels can be used without a torch or heat
radialarm
Clown of Death!
This works for me, it's what Ford says to do!!!
1: Drill an 1/8" hole into the center of the rivit, but not all the way through.
2: Drill the 1/8" hole out with a 3/8" bit to the same depth.
3: Cut the top off with a cold chisel.
4: Use a punch to remove the rest.
I tried grinding them off and they would hang up on the other side.
If you follow the procedure above you wont believe how easy it is!!!
polarbear
just growing older not up
12,878
607
Boring, Oregon
Yeppers.
They're huck bolts. Rhymes with another word you're likely to say while trying to remove them.
F 150Cobra
3,642
104
Aruba
those bastards came out... was allot of work ( for patricks a.k.a tuffjoker ) i just watched:p i wanted to learn soo.. hey knock yourself out!..
pics tomorrow
5.0
FTF'er
1,319
64
In the Middle
Yeppers.
I've never seen a huck bolt used on a pick up truck. I've seen them many times on larger trucks, though.
Yep. :)
...and rail cars. :)
We used them on some "insulated joints" one time as an experiment. :)
Huck bolts look like regular bolts except the threads are -rings-.
The heads tend to look like carriage bolts but don't need the square
or oval part underneath it to keep it from spinning.
The end of the new Huck-bolt gets pulled off and pops like a pop rivet.
I spark tested the rivets from a radius arm and they spark tested like
a common nail or grade 2 bolt, not like a grade 5 bolt or "cement" nail.
I use a little hand grinder to get the head off and punch the rest out.
Works slick as anything for me. :) YMMV if you aren't good at using a
hammer and punch. ;)
Alvin in AZ
5.0
FTF'er
1,319
64
In the Middle
Kid's '06 Ranger has 'em on the frame crossmembers. :headbang:
Maybe so, but not in the "1987-1996" section smilietease
This is the method I use also, but I hold the punch with a vice grip so I don't hit my hand with the hammer, lol.
