Thought my Bronco might need some adjustable bushings, but turns out it
don't.
One front tire had too much camber since I got it. :/ It leans to
the driver's side
I measured the crap out of everything underneath it including whether the
frame was square, diamonded or twisted. Turns out it was only-not-square
with the -ground-.
So, I put a scissor jack between the rear axle and the frame (driver's side)
and jacked it up to the point the Bronco was squared-up in -all- directions
and, its funny "cocked" front wheel it had, was straightened-out too and
so then it matched the other side -perfect- at that point.
So now I know what I need to do.
I'll re-arch the leaf springs myself using a sledge hammer (BTDT before on
my '75 F150) and that'll straighten the whole works up, like the scissor jack
did.
Might have to tweak it if I don't get it right-enough the first time
but I know I'll get it real close-to-right the fist try.
Whatcha think?
How squared-up is the rear suspension on your truck?
Alvin in AZ
don't.
the driver's side
with the -ground-.
did.
Whatcha think?
Alvin in AZ
