surewhynot
Rep whores make me sick
Let me add that you also need the longer straps for the Bronco tank. I have one in my 94 F150.
Maybe because that truck with the Centurion conversion was just meant to be a looker around town instead of a work truck?Does anyone know why ford motor company decided to put a tank that small into a truck that gets 16 miles to the gallon an a GOOD day?
At least the Red ones were, right Mike?The bed tank is sounding like a little less work and trouble. I think I'll look into a little more then see, not sure I want to give up my spare tire mount since the bed of my truck is usually loaded down with feed hay or saddles so the spare would just be a pain in the behind if it was stuck in the bed. Thanks for the input, need to do a little more research and see how the bed tank is put into the truck and all. since i already have a tool box I guess I'll have to give it up if I go that route though. hmmmmmm I guess I have to give something up either way.
Maybe because that truck with the Centurion conversion was just meant to be a looker around town instead of a work truck?At least the Red ones were, right Mike?
EDIT: aren't bronco's more narrow...like flareside narrow. so on a full-size, the arm wouldn't be long enough
I have seen Reg cab short boxes with 2 tanks around here all the time.
The frames were stretched (Reg to crew) and if I remember right the mid ship is not a easy bolt in for them.I'm a little confused, I check the parts catalog and the 95 F150 list a aft and a mid tank. The aft axle tank shows 18 gallons and the midship tank 17 or 19 gal depending on options, wheel base etc. so why not add a midship tank, not that you can get it from Ford any more, but there are tank places out there. one place I have used for years when I was in Calif was Arrow tank
http://www.aerotanks.com/ give them a shot might be a way for you to get what you need.
Ed
Larry,Not 4x4's . The last Reg cabs with duals were in late 80s' . I had 6 new reg shorts and would have loved the extra tank, But was told not option . Most I see have just used beds from sc trucks and they had 2 tanks..
