Honk Honk!
Mr. Stroker
CASE IH
3,121
67
Michigan
Yea no honk honk for me. How do i go about diagnosing it? Could be the clock spring yes, but how do i make sure? Heres the problem, dont honk when i hit the switch(s), But Honks when i push the theft button on the key fob. Thanks
Sounds like it's probably the clock spring. Do you have an airbag?
Brian_B
blank
I am sorry. I know this is tech and I am not supposed to post in here (off topic), but that is the most unusual thread title I have ever seen.
Me---> :confused:
I had to open it to see what it was. :suspicious:
Mr. Stroker
CASE IH
3,121
67
Michigan
Yeash... I does
Mr. Stroker
CASE IH
3,121
67
Michigan
Got your attention didnt it lol
89frankenford
Grabber Green Consultant
4,547
147
NH
yeah i would say either a bad clock spring or possibly a wiring problem.. but ost likely a bad clock spring
My buddy's 93 Bronco didn't have an airbag from the factory... The reason I asked is because the clockspring also deals with power to the airbag, and if it was going bad you might also have problems there (like an airbag light illuminating). But if you DON'T have an airbag, and your horn button is malfunctioning ONLY, I would suspect bad clockspring.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
The clock spring is probably bad, will also affect your cruise too, airbag works of it's own ckt. If you look cruise and horn use the same ckts.
Mr. Stroker
CASE IH
3,121
67
Michigan
Thanks man, Im guessing your using alldata, if you are could you please copy the procedure to replacing it? If not its no big deal i can get it monday when i go to class. Yea i would be estatic if my cruise didnt work because of that, but im pretty sure my horn worked before, and i still didnt have cruise. But hell its worth a shot. My airbag light comes on when i first start the truck, and like 2 seconds later it shuts off. Only my ABS light stays on, im gonna run some codes for that. Chris, your buddys bronco had that big ugly steering wheel, my steering wheel is just like yours, which i LOVE! LOL beleive it or not that helped me deside to buy a truck like that. I love the looks of it and how comfortable it is. But im weird!
Mr. Stroker
CASE IH
3,121
67
Michigan
Hey thanks man. Got somethin to do today lol
