gutless 400
11
So, my 79 is super reliable, but no B*lls!
should I rip out all the smog junk, thro in Edelbrock 2171pk carb/intake/cam/lifters Voila! 300 HP. Opinions?
F250 with service body, 4x4 4spd man. work truck. used for towing. budget under $1000. thanks. BL
Before you do any of that, do a compression test and make sure the cylinders are good, cuz it would be pointless throwing money into a trashed engine. If that checks out, Do it. Although, I think that 300 is bit optimistic, I'd probably say more around 250 at the engine. Go with the Eddy intake, a carb no bigger than 650 cfm and these engines seem to like the 255DEH and XE262 cam kits from Comp.
Can buy a Weiand Stealth intake for cheaper but if yours comes in a kit then you're probably better off with the Edelbrock
37
pull the engine strip it down take it to a a machine shop have it punched .30 over. $400.00ish
piston rings $60.00ish
Bearings: 50.00
Timing Chain: $30.00ish
Cam&Crank Timing Sprocket: $30.00ish
CAM and Lifter set: $200.00ish
Cam Bearings: $23.00ish
Polish the valves yourself with valve grinder: Free
Valves: $80.00
Overhaul Gasket kit: $60.00
Intake manifold Performance: $200.00
Carb 600cfm (used): Under $200.00
Total: Roughly $1300.00 and your labor I over priced most of this from
http://www.rockauto.com/catalog/raf...de=1432865&parttype=6956&a=FRc1432865k1288687
and
www.summitracing.com
Do all this and you will have a motor that will go forever and have great tq and hp. I am sure I forgot a few things but you get the jist.
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
Weiand Stealth isn't made for a 351m400. There are two current bolt on choices, the Edelbrock Performer or the plain Weiand.
I did a 265Deh CompCams valvetrain (bumpstick, lifters, pushrods, straight up timing set, valve springs and keepers), Edelbrock Performer intake, and a Holley 670 T/A carb. It turned my 400 into a completely different animal.smiliepeelout
Bearings: 50.00
Valves: $80.00
and
you forgot to add a couple hundred for pistons
To the 77 400 in my 'scapers F-250 converted to dually we added Weiand intake, Holley carb, Summit 14x3 air filter, Summit air cleaner tri bar nut, Summit headers, cam/lifter kit, timing chain set, Fel pro gaskets and Edelbrock chrome valve covers for about $915 from Summit Racing to the shop door. Got rid of the emissions crap, reassembled and he had the biggest smile as he smoked all 4 rear tires leaving the shop. If your long block is good with compression and oil psi that's less than a grand, take out the chrome and save $75 bucks and $850 will wake her up. I don't know what the exhaust starting at the headers will cost by you, He got away with 18' of 2 1/2 pipe, 6 clamps, 2 Cherry Bomb Turbo muffs and 2 turndowns, ends just before the back axle cost around $100 or a bit less, which may put you over budget but not by much.
