Grabit screw extractor
smokey
Hitech hillbilly
Those have a 50/50 chance of working. I have a set of them. I have better luck with left handed drill bits.
Some times I cut a slot with a dremel and get them out. other times I just grind the head off with the dremel or die grinder.
wareagle
War Eagle
1,935
40
Hickory, NC
Yeah, didn't have any luck at all with this set. Will try to take them back to Lowes tomorrow and see if they have some left-handed drill bits.
Thanks Randy.
I usually cut a slot for a standard screw driver, or impact screw driver.
If that fails your halfway to cutting the head of.
I've also ground the head off, then cut a slot and screwed it on in to have it fall out the other side.
