^^^Yeah, I just googled 1990 Ford rear axle code 73 and 1990 Dana rear axle code 73...and the handful of charts that I found that even had a code 73, what I posted is what they said.
So then does that mean the rear axle has been replaced? Or your truck is actually a 91?
Well damn...5.13's and what, a 31" tire? That thing has gotta be screaming, gotta be around 2500rpm at city speeds (45mph). If that's the case, that's nuckin futs.
Ben's info is correct except for the year application. 1990/2001 Ford Truck Parts Catalog sez:
73: Dana Rear Axle / 5.13-1 / non Limited Slip / 11,000 lb. Rear Axle Capacity.
Applications = 1990/97: F(Super Duty), E(Super Duty w/Ambulance Package) & F53 (Stripped Chassis).
btw: The VIN "tag" is located on the left (drivers) side corner of the dash, visible thru the windshield. All it has stamped on it is the 17 digit VIN
The AXLE code is listed: On the Certification Label, 1981 thru today // On the Warranty Plate 1957/80 //On the Rating Plate 1948/56 (the actual ratio is listed).
First use of a VIN on Ford Trucks: 1948 (Passenger Cars: 1949). The VIN (Vehicle Identification Number) registers the entire vehicle.
1947 and earlier Trucks (1948 and earlier Passenger Cars) were registered by their specific engine number. The major problem was: If the engine was changed (very common), the numbers no longer matched.
Les Kelley, a long time Ford Dealer and the largest used car dealer in the world (Kelley Kar Co. located on an entire city block on downtown LA's auto row [Staples Center, LA Live & the LA Convention Center is there now]), and originator of Kelley Blue Books, was the person that came up with the VIN system.
