Fuel Pump
Powerfun
Orange Ford
I noticed that when my 460 is idling the see-through fuel filter does not stay full. It will go close to empty and then refill. Also the fuel pressure goes form 6psi to 3-4 psi after the engine is warm, is this normal?
I never looked at my fuel filter to see if the same thing happens but it seems logical since the engine isnt spinning as fast at idle so I would think the pressure may drop like you say. Are you having any actual fuel related issues or did you just notice this by accident?
Powerfun
Orange Ford
Just noticed after I reinstalled my carb. I suppose I should rev the engine up to see if the pressure comes up!
fuel pump pressure on 8 cylinder fords should be between 6.0 - 8.0 according to the manual for these trucks.my 79 460 runs 6.0 at idle,it should not drop below that.my pump is brand new.your pump may be getting weak,or you have a restriction in the line.
dakonthemountain
California Chapter member
smilieIagree However it is normal to see air space in the filter... at least in all the filters I have every had, including in perfect running newer vehicles..
Dak
