My 1994 didn't have any camber adjustments so I'm not sure how new it would need to be. Didn't they stop using Twin I Beam in 1996?
hell when ya drop the 460 in... your gonna get some drop...
I just took a look-see, and got sick of seeing a bunch of crap. I thought about it, and there's really no way to adjust camber on an IFS suspension without having the camber adjusters. I know for sure they had them on 4x2 trucks in 85.
Generally, they look like this.
Napa sells some adjustable ones that can adjust camber up to 4 degrees or so. I think they have to do some digging to find them though.
I think Advance has factory style adjusters, but you have to know exactly which ones you need, because they have all different types of degrees.
You'd have to find a way to measure how far off your camber is. Then, get the appropriate adjuster.
I have a general knowledge with the 4x4 stuff, and I think it carries over to the 4x2 stuff. I think your best bet Cliff would be to talk with an alignment shop and find one that has experience with 82-96 IFS Fords. Either way, if you can't adjust the alignment yourself, or at least get it close enough to where you can drive it, after you do the drop springs you'll have to have it towed to the alignment shop.
cut it.. and if it wont ride the way u like it then buy the beltech
