Front clip swap?
I don't think he would exactly ruin it. If you see an F-Superduty on Barrett Jackson then maybe...
Ridgerunner
573
Stillwater Ok
It looks right,but in Austin case he would also need to change the bed. To be Honest I am like Doug I see 94-96 all over the place compared to our Bricks.
I could possibly sell you all the parts you need Austin. Just gotta see what happens to the truck first.
Sounds good to me! And I could seel the parts on it now to make up some of the difference.
- I don't want to start/finish paint until I get the swap done. (If I do it)
I will give some credit to the brick front end... They are nice if done clean with the chrome and all, but I can't seem to get away from associating the front end with a crummy 'work' truck.
Ridgerunner
573
Stillwater Ok
Guess What???? You have a work truck
Ridgerunner
573
Stillwater Ok
385
soo...... something like this looks good? or no to you?
Not really.... Too 'work' truck and not enough 'dang that guy's truck is HOT' truck. smilietease
416
Ok, I have to ask, what year truck are we discussing? I thought we were talking about a 90, so the bed is the same... If it is an 86 or older, yes, the bed lines are different, 87 to 96 had the same bed lines.
1990 cab, 80-86 bed. The lines are the same, but the fender lines are different.
416
Ok, that explains. The only actual change is right at the fenderwell. The clip is a straight swap, the cowl is the same 87 up. It doesn't look that much different on that cab, but the box probably looks a little out of place now.
I could swap the flares out later down the line, if it bothers me enough! (The truck wasn't intended to come with a bed, so I'm thankful that I at least have one on there.)
I'd like to come across a parts truck to get the swap done. AND have extra goodies. :D
416
The tail lights and the tail gate are of course different too... Too bad it is so far away, a decent F150 here is available for $450, has some damage on the driver front, but the box and such are good, just the front sheet metal and maybe the suspension are buggered up.
I'll be in Pennsylvania in a few months... that's closer. :D
416
Not by much.... It is about a good 16 hour drive from here. But that is better than the 24 or so getting to your area...
That's just too much driving.
