Found small rubber hose dangling
wareagle
War Eagle
1,935
40
Hickory, NC
underneath my truck this morning. Raised the hood and the other end was in the same tiedown as the wiring for the windshield wipers. I assume this must be the wiper fluid hose? I don't currently have a wiper fluid container, so cannot verify for sure. Anyone have any idea?
Sounds like your assumption is good to me. Did you try tracing said hose?
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
If you don't have the reservoir, you cannot install the w/shield washer pump.
The washer pump (C8SZ-17664-A) fits into the reservoir (C8TZ-17618-A) using a gasket (C8UZ-17B610-A), lock ring (382243-S) and washer filter (C8UZ-17K608-A).
The reservoir has a round hole at the bottom, the filter goes in first, followed by the lock ring, gasket and pump.
1968/70 F100/350 is the same. The whole tamale (including the routing of the hoses and etc.) is illustrated here: 1964/72 Ford Truck Parts Catalog / Illustration Section 175.1, Page 1.
This catalog is available on a CD from hipoparts.com for 22 bucks. EVERYONE that owns an old rolling pile of misery, needs the apropos parts catalog!
This is the best I have right now.
3 Printers and 2 of them the computer with W7 won't recognize and the other is almost out of ink as you can see.
I'll be back with a better one.
Click each image it make take 4 times until you see a highly magnified image
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
:rotz: Ach du lieber! ^^ That's the WRONG parts catalog, WRONG illustration and the WRONG parts catalog reference! ^^
The OP has a 1970 .. not a 1973. Open your peepers: 1964/72 truck catalog: Illustration Section 175, Page 1.
1973 uses totally different parts than 1968/70. 1971/72 is different than 1968/70.
If you don't post the correct pics, all that does is confuses peeps...and some are confused enough already.
wareagle
War Eagle
1,935
40
Hickory, NC
I have that CD at home (thanks to your suggestion before).
And I did realize I needed the reservoir (among other parts), was just curious how the pump was mounted.
And I agree. I am confused enough already.
396
There are universal type units out there if you would so choose to do so.
396
I was thinking we had them in the store, will look into it in the morning
396
Autozone, for now. I get done with my engineering classes, that will be done.
396
Part #9-400, $15.99. Held it in my hand... Just couldn't find it in the computer, imagine that... :rolleyes:
wareagle
War Eagle
1,935
40
Hickory, NC
396
Since it is universal, it is not a direct fit, which is all that means, so you have to set it up. You have to wire it(two wires) and make it mount. I can get dims if you want, but don't work again until Sunday.
wareagle
War Eagle
1,935
40
Hickory, NC
I will check it out again. The connectors are already there on the wiring harness, I just need to find out the dimensions of the reservoir to be sure I can find a place for it to fit.
396
Nearly forgot about getting the measurement, did forget for a while, but happened to remember today. It is approximately 8'" tall, 5" wide, 4" deep.
