89frankenford
Grabber Green Consultant
ok so ive got a decision to make. over the course of the winter im planning some major things to do to my truck. some examples include, f-250 coil springs in front to raise the front up level with the rear, somewhat waterproof electrical components in engine bay, put my new drivers door on and switch the door insides from the old door to the new to keep power everything, put an air/fuel ratio gauge in, and a gauge to be determined later (all in a pillar pod), put a Bronco spare tire swing carrier on the truck so i have somewhere to mount the spare without taking up room( i use the bed constantly and i can't fit it under the truck due to the tires being 33" and i have my dual exhaust going straight back) and last but not least i want to put a front mount trailer hitch on. i plan on making my own from either 2" inside diameter square tubing stock or i beam stock. it will go be welded between the front frame rails and just under the radiator support and be hidden driectly behind the front bumper. the front plate frame will be spring loaded and flip up to expose the 2" reciever so i can either mount a detachable winch, or a trailer tongue. BUT my problem is i have push plates off of a 9th gen truck that i got for free and want to put on so i can have a plow. now i can't do both hence why i am writing
. the push plates are for a minute mount plow which is awesome but will they fit my 89? i know the front of the frames changed slightly between gen 8 and gen 9. if they will fit i am going to just do the plow setup and make a brakcet for a front receiver from that. if anybody can help that would be awesome!
