- 67
- 0
1976 F-250 2WD 460 with C-6. After market ammeter and voltmeter guages ( along with one or two others) installed. Situation: While driving at night with headlights on and heater on 'medium' or hi and lights in low beam or high beam function , headlights drop out...as in...they go out. Tail lights and dash lights continue to operate with NO visible voltage loss or gain seen on either of the two gauges. I've replaced the headlight switch,dimmer switch and inspected all wiring in that circut for headlights and find NO breaks,shorts, or any other apparent cause. Is it possible , that while the heater is in operation that the circut for the headlights is over loaded?. Altenator is a 50 or 70 some amp output and Voltage Regulator is in good working order ( full feilded the alt ever so breifly and have tested out Voltage regulator). This is inhibiting my abilty to drive long distances at night as when I apply the heater , thats about the time the lights begin to go out but yet leaving me with running lights and dash lights. Any suggestions????
