Ebay 5.8 ecu
Lost
PA Chapter leader
3,288
central PA
Lost
PA Chapter leader
3,288
central PA
For the price I might buy it and set it on shelf . I dont run 351's but I may need a tow truck one day. Course it may be hard to find a harness for it . R CAlifornia Trucks wired different ? 2 o2s for instance or still OBD1
MOB1 is the catch code for my computer. It'll be Cali MAF, two o2 sensors, obd1, e4od.
EDIT: Clarification-- the o2 sensors are 1 in each downpipe; not 1 in the cat like the obd2 setup.
andym
Real men are fanatics
604
Roseville, CA
You sure you have two O2 sensors in your truck Chris? I thought OBD-I trucks had one sensor.
Absolutely positive-- I replaced them with Bosch sensors a while back (both at once, which I hadn't used Bosch). I've got one in each downpipe. I'll take pics if you don't believe me smilietease
The difference between mine and the OBD-II trucks is that the OBD-II's have a bung in the catalytic converter for an o2 sensors. Mine are further upstream towards the engine, measuring PRE-converter o2 levels, instead of post.
Lost
PA Chapter leader
3,288
central PA
yea I did a 351 MAF conversion using 302 MAF parts for guy while back (he never did get a 351 ecm .) And looked into what all I needed.
I think the maf 302 out there also had dual o2's
