I should have done this a LONG time ago...
So since I've been hanging with Rick-- he has showed me his e-fan setup on his Bronco. He's using the fan from a V8 t-bird. I didn't know but the t-bird is very similar to the taurus fan: 2-speed and pulls a buttload of air. He showed me his setup and I saw that the t-bird has a MUCH bigger shroud and a MUCH bigger fan (the actual diameter of the fan blades). Not to mention that the shape of the fan blades is a better design for pulling air. His shroud covered almost all of his radiator.
I've always been somewhat unhappy with my taurus fan because it didn't cover the part of my radiator where my trans cooler was, so my trans could start to heat up in traffic, etc. So after seeing Rick's sweet setup with the t-bird fan and his custom mounting brackets, I started gettin' ideas
He fabbed me up some brackets like his and I got to work looking for a t-bird fan. Finally found some at the PnP here near my moms house (and they had TONS to choose from). I grabbed two (1 for a spare) and headed home. Took about 2-3 hours to get everything drilled, mounted, and wired, plus that fact that I cleaned up some of my messy wiring from last time (running bare wires through bare metal holes, missing split loom, etc).
HOLY CRAP!! The t-bird fan pulls way more air and pulls LESS power. Before-- I'd flip it on high speed and there'd be an initial surge from starting the motor, but the gauge would not return back to normal unless the engine is turning RPMs higher than idle. Now I've got the surge but the gauge climbs back up to normal even at an idle!! I'm thinking that perhaps my taurus fan had a little resistance in the motor which was making it pull too much power. Either way-- I'm much happier with this setup. Here's the comparison pics that I snapped while there was still some light outside. I finished after dark so I wasn't able to get any pics of the finished product. Those will come later
