So, last night, I had to go to a client's to do some work and I left my lights on on my POS Dodge Plow Truck which I was using. Went out to start it 4+ hours later and nothing. Called a friend to come jump it and after we let it charge a little and started it up, it just dies.......
When key is turned to on, voltage reads 12-14 and it'll start, but then die.
If I push on the gas, it will continue running until I let off the pedal and then it'll die.
The only thing that changed in this thing was that the battery died.....why wouldn't it stay running once we jumped it?
Any thoughts.
Going to have it towed home to charge the battery with a charger and see what happens. Then if that doesn't work, my next step is to get a new battery and if that doesn't work, then off to the freakin garage!
I thought this part of mechanics was simple....kill the battery, jump it and you can at least drive it home.....but no!
Any thoughts.
