Check Engine Light
Got a CEL that goes on shortly or right after start up then stays on for about 10 to 15 minutes. Going to get a code reader sometime, more info to come.
smokey
Hitech hillbilly
For a 88 all you need is a test light and a paper clip to read the codes.
Might even flash the cel when you short the connector. Dome years didn't flash the cell.
I know you can flash it but I'm going to pick a a code reader anyway. Not much money and nice to have.
I paid $20 for my OBDI Ford code reader and it was worth all of the $20 I gave for it. Let us know what it says.
nobodyspecial
Fire in the hole...
5,756
366
ND
A piece of electrical tape over the light works, too.
HEHE...I like to call that one ol' trusty. I've driven a few chit boxes, where the only thing not electrical taped over was the speedo...ahaha.
nobodyspecial
Fire in the hole...
5,756
366
ND
Electrical tape did the trick, huh?
120
Taking the bulb out is much more better fix. LOL
nobodyspecial
Fire in the hole...
5,756
366
ND
No, tape is quicker and easier. Thats what maintenance is all about. quick and easy.
godblessmud
CHECKERS OR WRECKERS
1,596
63
Moscow, ID
semi clear masking tape, that way you cant read what it says but you get a orange glow so at night with the green from the guage cluster, red from the needles and orange you can pretend your flying a spaceship
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
sounds like you speak from experiance smiliegitrdone
godblessmud
1,596
63
Moscow, ID
hell yeah I got green from guages, red from needles, orange from CEL, green from CB and red and blue from the fuzz buster..im goin to the friggin moon when i drive! Of course the guages are just for looks except the fuel, temp and OP cause my speedo and tach aint hooked up to anything
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
I have green lights on my dash too, but the oil pressure and fuel gauges don't light up, and the temp and i forgot what the other is... amps maybe (don't work, never had a reason to look at it). so all I have to look at is the speedo, and I have green from my CB.
It's all one color for me..
Good thing you're not epileptic.
