Chasis Project
Ok so I needed a project for my chassis fab class and my wife told me to take her truck and turn it into a street rod
76 f100 390 motor with a t18 4spd
What she wants is a street-able daily driver type deal so my initial thoughts were to box the frame give it a slight rake possible airbag conversion and throw a 9 in in the rear the big project I was thinking was a mustang 2 front end keep in mind really the only pre-fab things I can go too would be things like the airbags themselves
The other option would be to do a complete tube frame. Ironically with the steel prices for either project the actual frame whether in tube or boxing would be near the same price.
I am feeling that the tube chassis would be a better investment since it would be much easier to run headers I know for these years they are hard to find that fit correctly.
My question is who has done something like this what am I going to run into pictures of suspension fuel tanks and such or if you have ideas that would be nice as well
Boxing the frame really isn't needed. Unless you are going for high torque and such, it gains nothing but a lot of work. It will not improve the ride, unless you figure in the additional weight... Actually, it could make things stiffer, and reduce ride quality.
Personally, I am not a fan of the M II suspensions. There are much better units to work with. There are some writeups on the net, might even be one here about using a later (2000's) Crown Vic suspension. They are bolt in aluminum cradles. I have also discovered that Aerostars use a bolt on front suspension as well. The trick to a tube frame is getting everything aligned and hooked up correctly. It depends what your experience level is as to how realistic a plan it is. Myself, I would stick with the factory frame and work with that, but I am not really a fan of total slammed trucks either. I like some decent ride height, even on cars.
You should already have a 9" rear already, so that aspect should already be done...
Pattern is 5x4.5, I will have to see if I can get something decent on how it mounts anyway. The main frame of the Aerostars are unibody, and they use shocks and a-arms for suspension.
yes, as well as many Ford cars.
primetime
sawmill slave
1,495
64
Onaway Michigan
SN-95 (94-98) and older Mustangs as well had the 5x4.5 bolt pattern..
Almost. SN-95 Mustangs (94-98) do have a 5 on 4.5" bolt pattern. 79-93 Mustangs were 4 lug. As were Fairmont and Ltd II. Mark VII did have a 5 on 4.5 pattern.
