- 9
- 0
I am on a journey to do a build of my newly acquired 1962 Unibody. Found the truck on CL and picked it up for $750 from a family that just did not need it anymore. The truck is in excellent shape for its years.
What I liked about the truck was that it was almost 100% original, except for the tires and rims. Has the original 292 motor and Holley carb with oil bath air cleaner, interior untouched and the original paint with a little patina.
After making the deal with P.O. I worked on the truck for a couple hours seeing if I could get it to run so I could drive it home, which is about 8 miles down road.
Got it to fire up a run at a good idle. Went home to return the following day with my son so he could follow me home incase there was a problem.
Returned on Sunday the truck fired right up and I headed down the road, got about two blocks and it stop running. Popped open the hood and noticed the fuel filter was a dark brown to black color fuel. I was scratching my head because I completely drained he tank the day before and put in 5 gallons of gas and some seaform.
Ended up towing the truck back to the PO home and parking it out front of the house. Removed the tank and took home to see what was up with it. After removing the gas and letting it evaporate out the remaining gas I took a look inside to find a very clean tank, however right below the pickup tube was a black tar residue.
I have had this problem before with older Chevy trucks I have purchased and I knew how to fix the problem...score!
I put about 4 cups of laquer thinner in the tank and let it sit for about 30 minutes. The laquer breaks down the tar residue, rinse and repeat a few times and I was good to go.
Went back a few days later installed the tank and fresh gas , and replaced the fuel filter. Got it started but now another small problem, the card was leaking onto the manifold so I shut it down and decided that i would tow instead of taking a chance on a fire happening.
Headed over to Harbour Freight and picked up a towbar for $60, took it home and added heavy duty safety chains.
Return early Saturday morning since i new the roads would have less traffic, took my generator , drill and tools with me so I could mount the brakets to the bumper. Took about ten minutes to get it rigged up and I was on my way.
It is now back at my shop and ready to go to work. herwe are a few pictures of the truck.
Here is a actual picture of stance
Here is a photoshop of the stance
