Broke off an exhaust mainfold bolt
Keep drilling :)
Yes, but you should be fine with just drilling and tapping
Get that thing glowing cherry red and use the spiral. Give it hell.
If you can reach it with a punch slightly smaller that the bolt. Put it on the bolt and tap is to just to jar the bolt a little do this while applying the penetrating oil (I recommend Kroil if you can find it, great stuff) The vibration from the punch and tapping helps wick the oil through the threads mating surfaces and may help it break loose when you attempt to remove it. A reverse style drill does work well and the trick with easy-outs is to know when to stop. Tapping on the easy-out helps too. Good luck. Redxlt
39
Well, I have almost finished tapping the front hole, (the right one in the picture). It is a little crooked, but not to bad. I think it will work.
