When did Ford go from the C6 to the overdrive in the 3/4 and one ton trucks?
Dec 20, 2007 #1 1970Custom They call me Spuds 14,107 447 Middleton, ID When did Ford go from the C6 to the overdrive in the 3/4 and one ton trucks?
Dec 27, 2007 #2 d-kuzmen Master Ford Tech 2,109 79 Connecticut Check this site out. It'll give you the info you need. http://en.wikipedia.org/wiki/Ford_C6_transmission
Jan 4, 2008 #3 testresearch 1 1 E4OD Transmission 1970Custom said: When did Ford go from the C6 to the overdrive in the 3/4 and one ton trucks? Click to expand... The E4OD was introduced in 1989 into the F and E series HD applications.
