anyone know of any good cheap lift kits. im looking for a 2 inch so i can run bilstein 5100 shocks
Apr 14, 2011 #1 SuperGizzman Mangstafusauceinator 80 0 Gretna, nebraska anyone know of any good cheap lift kits. im looking for a 2 inch so i can run bilstein 5100 shocks
Apr 14, 2011 #2 LEB Ben Arrogant A-hole At-Large 34,919 1,124 outside your house For 2", I'd do AAL's and coil spacers. Not the best or most functional way to lift...but it'll do the job. That said...why can't you get the correct length Bilsteins with the height you're at?
Apr 14, 2011 #3 SuperGizzman Mangstafusauceinator 80 0 Gretna, nebraska i asked bilstein in an email if they made the 5100s in stock height but they never replied
Apr 14, 2011 #4 LEB Ben Arrogant A-hole At-Large 34,919 1,124 outside your house I dunno why they wouldn't...I think we have a vendor here that supplies Bilstein, can't remember which one, but they should be able to help you out.
Apr 14, 2011 #5 SuperGizzman Mangstafusauceinator 80 0 Gretna, nebraska ok do you know the name of the place
Apr 14, 2011 #6 LEB Ben Arrogant A-hole At-Large 34,919 1,124 outside your house Naw...I can't remember, but I remember a couple members have bought from them. Can anyone assist.
Apr 14, 2011 #7 FordF-SuperDuty 4,391 142 Ballwin, MO Tirerack.com carries them. I'd go leveling springs instead of coil spacers.
Apr 14, 2011 #8 Lost PA Chapter leader 3,288 33 central PA F350 2wd coil r 1 3/4" over a new stock spring but if your coil have not been replaced in last couple years it will be more. Any level coils u may have to get chamber kit so wheels /tires dont lean, There r several out there I'm looking at a 2.5 has drop brackets coils shocks rear blocks ( rather have extra lift leaf but for price.) Look on ebay to see whats out there then go local . Avoid spacers used coils instead you'll be happy later
Apr 15, 2011 #9 SuperGizzman Mangstafusauceinator 80 0 Gretna, nebraska Well skyjacker makes a 2 inch kit for 255 seems alittle expensive for a 2inch lift
Apr 15, 2011 #10 FordF-SuperDuty 4,391 142 Ballwin, MO SuperGizzman said: Well skyjacker makes a 2 inch kit for 255 seems alittle expensive for a 2inch lift Click to expand... To my knowledge that kit doesn't include the camber/caster bushings. I've looked into 2in lifts and this combo seems to be the cheapest. http://broncograveyard.com/bronco/i-33701-1-5-2-inch-f-150-supercab-4wd-leveling-kit.html http://broncograveyard.com/bronco/i-33578-superlift-3-3-add-a-leafs-rear.html
