Anybody try firming-up their bench seat? :)
Hmmm...I'm not sure a spring is gonna do the trick. I've seen guys use denser foam and thicker lattice wire, but I'm not sure how an expanded spring is supposed to help.
Oops! LOL :)
So you got me to thinking about the springs and how much they stretch
when I set down and felt under the seat. And found out there's a different
cushion-support-system than the one I was messing with that's out of the
'90 parts truck. :/ And it -was- going to be a cinch with its style of seat
cushion support too! :)
Already ordered the dangged springs. :/
Oh well, it's got the older squiggle-spring type seat cushion supports.
Guess I'll just have to figure out a way to add some of those somehow?
Got a bunch of those springs already.
Not sure if they are all soft like mine, stepfather was 6'6" and heavy too!
Alvin in AZ
I have talked to an upholstery shop here after a search for later model seats ended in frustration..the fellow I talked to said he can install a firmer, thicker spring...more dense foam and even a lumbar support if I wanted...all while keeping the original appearance.
Lost
PA Chapter leader
3,288
central PA
depending on the year the wires /springs cut into foam
After seat is apart I fix any loose bad wires and I put a pc of carpet on top of springs and then add Foam in any thickness needed
Here's what I found after I took the sorry piece of crap apart...
http://www.panix.com/~alvinj/file12/seat-springs.jpg
The one on the left is from my '75 F100 parts truck and the one on the right
with 6! springs missing is from the '91 F150 I inherited. Four of the springs
on the '91 seat aren't much count too because they are bent "square" and
weak. Those 2 surround the seat belt and made special for that purpose I
guess?
Ok, sounds weird but just sitting on the two as-is gives the same "feel" as
when they're all covered up with foam and fabric. No kidding, strange but
true. :)
The 6 missing springs don't have provisions to add springs, the factory made
it with those springs missing on purpose. :(
The seat I got from the '90 F250 parts truck and the rear seat from the '91
Bronco use a different spring system and would be easy as anything to firm
up, IMO.
Well there you got it not need for new foam unless you want it firmer than
a old clunky '75's seat. ;)
Now what to do to fix this situation? :/
Since I left the old frame out and it got rusty, the seat-back pivot-bearing
surfaces are rusty. :/ So I'm thinking I'd rather modify the new frame.
So now should I, pop-rivet some spring holders (made or bought) or try to
copy the factory's method of holding the 6 added springs by cutting slots
into the seat frame? Hmmm...
Alvin in AZ
guess?
true. :)
up, IMO.
Alvin in AZ
Why not give it a quick hit with a sandblaster and por15 then a rattlecan of paint - she'll be good as new then.:)
Why not give it a quick hit with a sandblaster ...then a rattlecan of paint
I went ahead and ordered these to get them started this way...
(got stuff from them the next day because they ship from LA)
http://www.mcmaster.com/nav/enter.asp?partnum=8863T32&pagenum=1497
...but might do it different way like you say. :) Not setup to sandblast but
it's more the bearing surface on the passenger side's got a nylon bearing
that I'd like to keep intact.
Ordered these while I was at it...
http://www.mcmaster.com/nav/enter.asp?partnum=9464K545&pagenum=3455
...they are for the fuel injection type sending unit hole. :)
This is for those that actually take one apart, otherwise this won't make
any dangged sense at all. LOL :)
FiNgured-out a way to replace those 4 springs that are "square waves"
and were wimped-out and saggy. Took two springs off the old seat and
bent the "straight end" to 45 degrees and then straightened the "45" end.
That-way the spring-steel only gets re-worked ~45 degrees, see?. :)
There's only one-short-straight-section of the wire that has to do all the
twisting. Remember to bend-past what you need and then bent-back to
what you want. ;)
Alvin in AZ
