My 360FE engine rebuilder swore up and down that advancing the stock
"smog" cam on those old '70's smogged-up engines would give you more
usable power and better gas mileage just using the stock cam.
So, wondering if doing the same... installing a certain timing set in a '91
351w guy could improve the fuel mileage and shift the power band down
to a more usable rpm? (especially for a manual transmission)
1.7 ratio rockers have been recommended to me over on FSB but wanted
to ask about cam timing, here.
If I were to mess with the stock cam
I'd want to change the timing first then change the rockers to feel the
effects. (tinkerers like to do things in a silly way like that)
On FSB "Fireguy" Ryan of "Ford fuel Injection" wrote:
- For a good {Speed Density friendly} fuel injection truck cam:
- Intake duration @ 0.50" should be kept at or under 210
- Gross valve lift should be kept under 0.500
- Lobe separation should be at or above 114°
Thread: http://www.fullsizebronco.com/forum/showthread.php?t=6867&page=6&highlight="cam+timing"
...the thread mostly sucks, lots of guys trying to worm their way around
those basic facts. :/ The first post (Ryan's) kicks butt tho!
But how much cam timing change for a '91 351w (125k miles)?
A full 4 degrees or 3 or 2?
Or, skip this business and only get rockers, like I was told? LOL
Alvin in AZ
Alvin in AZ
