96 f350 4x4 problems
Thanks but unfortunately I haven't got power to the switch either. I thought it might have been the fuel shut off switch and relay but I tried another from a different truck and no luck. I had it running the other day so I am not sure what the deal is.
Lost
PA Chapter leader
3,288
central PA
Fuel injection easy When they work
Figuring out what to do first time is hard .
Mine had bad connection at fuse box and did that
mfruendt
ASSET Teacher
If you have a 5.8L, the fuel pump relay in the Engine Compartment Fuse Box is powered by fuse #16, 20a in the same box. Power from the relay goes to the inertia switch on a DG/Y wire, then from the inertia switch to the Fuel Tank Selector Switch on a R/Y wire. From the selector switch power goes to either the front tank on a R wire or to the rear tank on a BR/W wire. There are two connectors between the switch and the tank. Both the front and rear tanks share a common ground.
