95 Explorer transmission slipping/disengagement
Took a friend's Explorer for a drive to try to see what is going on with it. Speedo is nonfunctional, but doesn't seem to be part of the issue. It will shift fine 1st, second, 3rd, then after a bit, it is like the clutch pack loses pressure and the rpms climb. Pull it to 2nd, works fine. O/d light flashing too. Hard part failure, or maybe just pressure solenoid?
3,291
188
In my own world
speedometer in these is a known problem. the fix comes in 2001
Trans shifts by hand means hydro side working, electronic side not. there is a code, but there is no adl to retrieve them.
My guess is connector on side has a problem, or a shift solenoid pack
masakimm
Native Texan
158
If the shop has a proper scanner they should be able to retrieve the codes we have an adapter for the older ford to read the code.s
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
The shop is me... It still has the old EEC plug, so the later scanner doesn't work, and I don't readily have my old scanner which has seen better days.
Basically, it felt like the hydraulics were fine, it would engage initially, then lose it after a bit. Doesn't flare like a slip, and grab again, just goes to rev and then nothing until I downshift. That is why I lean towards an electrical control issue over a hard parts failure.
3,291
188
In my own world
Ya. Using my buddy as an example.[emoji56]you can get the codes.
Take a test light, plug it into the little square single wire where the eec check is.
Ground out the test light.
Turn on the key. Sit in the seat. Count check engine flashes.
That truck will be a series of 3 flashes.
1 1 1 means system pass. It will do that twice, then give you the codes. Twice for each code
Post the codes, I'll decipher them for you
