88f-250 stalls every 3rd 4th trip
truck has 300ci fuel injected. only mid tank is used and it along with low pressure internal pump is new. replaced high pressure pump last week and it ran ok next two days. filter has been changed twice last time after high pump. just acts like out of gas than runs next day ok. has no stored codes and running codes show lean condition with coolant and air temp sensors out of normal range. both ohm ok and have 4.7 volts at plug. local ford garage is of no help. any advice on next step is greatly welcome.
CaFordDude
464
Cali
Welcome to the site Lewis. You made your first post in the perfect section. We have a number of Ford Tech's we are lucky enough to call friends that will surely come along and help you out.
In the mean time we also have a ton of very knowledgable shadetree mechanics that can throw some ideas your way.
:wavey:
Does your truck have a shraeder valve on the fuel rail?
Have you tried pressing it when the truck won't run, to see if there is any fuel there?
