- Moderator
- #1
It fired up great, then promptly died. It is not turning the fuel pumps on, and I don't believe it is pulsing the injectors. It has good spark, and will run off gas poured into the intake. I can activate the pumps fine through the test lead. Can the module drop like that, and cause a partial failure like this? Haven't seen such before... Obviously there is something blocking it from turning the pumps on. Also, the inertia trip switch is not tripped...
