'79 F250 4WD draggin a leg
Having problems with rear end, specifically right rear..Brake locked up on it going down highway, pulled over, right rear hub extremely hot, lube was spider webbed outer wheel as shown. Parked it, just now getting time to give it a look. The numbers are as follows: Would appreciate some decoding and thought on rear prob...
VIN---F265RFE8930
Rear---410 D81A SB
6039014LS
cO3255
Hello, again! Sounds like you might have a leaking wheel cylinder, which coated the brake pads with brake fluid.
