6.0L Diesels
6L PWR
Kansas Chapter member
7,961
255
Osage Beach, MO
6.0L Bible:
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
High Idle Mod Instructions:
http://dan.prxy.org/Truck/Other/High_Idle/High_idle_mod.html
Fuel Filter Changing Instructions:
http://home.austin.rr.com/sbv1/Procedures/fuel%20filter%20change.htm
Oil Filter Changine Instructions:
http://home.austin.rr.com/sbv1/Procedures/ChangingEngineOil.htm
Air Filter Changing Instructions:
http://home.austin.rr.com/sbv1/Procedures/AirFilterRR.htm
Fuel/Water Seperator Draining Instructions:
http://home.austin.rr.com/sbv1/Procedures/fuel-water-drain.htm
Torque Shift Transmission Relearning Procedure:
http://home.austin.rr.com/sbv1/Procedures/TorqushiftShiftRelearningStrategy.htm
Transfer Case Fluid Change Instructions:
http://www.guzzle.rbmicro.com/transfer.html
SRW Differential Fluid Change Instructions:
http://www.guzzle.rbmicro.com/rdiff.html
Front Differential Fluid Change Instructions:
http://www.guzzle.rbmicro.com/fdiff.html
Greasing the Driveshaft Slip Joint Instructions:
http://www.eurekaboy.com/f250/slipjoint.htm
thanks for posting this up. This is a great place to start for people with questions.
Beachbumcook
883
38
Kansas City
Need a tech page or forum just for this kind of stuff.
I would have a forum just for this kind of stuff. Very usefull and people will need to search it by motor type as this is the most relevant way to search or maybe my truck model????
What a great start... I was going to post the same... but you guys beat me to it.
Beachbumcook
883
38
Kansas City
API CJ4 Oil Discussion / Web Link (Q & A)
Here is a great API Q & A on CJ4 oil (Relevant to the 6.0L PSD).
This info is relevant to the 6.0L and 6.4L motor... but since there is a "sticky" for important links... I am posting here.
http://www.apicj-4.org/faqs.html
Beachbumcook
883
38
Kansas City
Beachbumcook
883
38
Kansas City
Oil Testing Lab (Link)
Here is a very popular lab that does oil anlaysis and provides a pretty detailed report. They offer free test-kits and it takes less than a week to get your oil tested and the results emailed back to you in a PDF file.
http://www.blackstone-labs.com/
