1970Custom
They call me Spuds
So I'm having issues with my 408W, it's gone through two autos (one was behind my 302 for four years prior). Had both looked at and something caused the input shaft to be stuffed into the pump and destroyed it along with scorching the TC where it meets the crank.
There's no unusual noise coming from the engine when it runs, the converter(s) was seated properly, flexplate was not distorted and was correct for the engine, nothing in the crank (i.e. pilot bearing etc), engine does seem to have a bit more vibration at an idle than what I'd expect.
I was told to check for crank walk or the thrust bearings, I have a new set of bearings for it but have never put them in, could it help fix my problem?
