- 67
- 2
Sorry, more questions, on a roll again with some final major work...
Question 1: I am dropping transmission end of week to change the flywheel, clutch, and u-joints. I found this Eaton Transmission, 5 speed on CL (link below) from a newer ford. Will it and can it fit on my 1974 F350 with 360 5.9L engine? If so, then what should I be prepared for trouble wise (assuming just won't fit right)?
https://asheville.craigslist.org/pts/5120174081.html
Question 2 (More important): I am also going to finally get rid of the split rims. The only ones I found that match are from etrailer (link below). All specs match (lug spacing, pilot hole, notch for back dullies, offset, etc.), did the measurements, and load limit for each rim is 3500, more than enough. I know they are trailer rims, and that is all they tell me when I have talked to them through email. I have also included pics of my current rims, exactly the same (below link to new rims).
http://www.etrailer.com/Tires-and-Wheels/Taskmaster/TTW660865SDX1C.html
