will a oil pan off a 88 351w fit a 1980 351m? thanks
Oct 2, 2009 #2 LEB BenArrogant A-hole At-Large34,9191,124 outside your house No...completely different animals
Oct 2, 2009 Moderator #3 FellroModeratorStaff member7,953361 Iowa County, Iowa not even remotely close. Only pan to fit is another windsor.
Oct 2, 2009 #4 LEB BenArrogant A-hole At-Large34,9191,124 outside your house Fellro said: not even remotely close. Only pan to fit is another windsor.Click to expand... You corrected it in the other thread that he posted, you got the swap backwards...but only a 351M/400 pan will fit the 351M.
Oct 2, 2009 Moderator #5 FellroModeratorStaff member7,953361 Iowa County, Iowa I was thinking he was trying to get it to fit a w, so that is why I stated only a w pan will fit a w motor. Still correct, just wrong subject.
