1970 f250 custom no tranny dip stick?
1,320
82
Automatic transmission, correct? Manual stuff does't use a dipstick. It should be behind the passenger side cylinder head if it is a V-8. Look at the firewall on the pass. side.
Derek.
jebadiah04
Rooster Snorkler
849
27
If its a manual, it will use fill plugs to test level
Sent from my mudwhistle via Lemmiwinks.
jebadiah04
Rooster Snorkler
849
27
Unscrew filler plug, then u feel for fluid. Do this cold of coarse.
If you have little fingers like me, you can put your little finger in the hole and bend the joint down. If you get fluid on the tip of your finger, the level is adequate. If not, add fluid to the same hole until it just begins to run out the hole.
