- 8
- 0
I'm struggling to replace a reservoir valve (Two gas tanks) and need to know howq to re-connect the lines...like, which is the feed and which is the return line? I'm finishing this job after an abandoned attempt by a rogue mobile mechanic. It appears that two lines are grouped higher along the frame and there's a pair lower along the frame. Can someone tell me which is which?...need same answer for the pair of lines exiting towards the motor. Thanks.
