Storm
Registered User
Well.. Lets just say this was one adventure I NEVER want to do again.. Talk about a pita to install.. I started at 6:30pm, was done at 1:30am.. They are the hardest damn things to install.. There are so many points you adjust, that once you adjust one part, 3 others screw it all up.. I went through hell getting my stacks the same height, and angle.. One is 1/8" off, I gave up.. They are tilted forward like a degree.. I notice it because I'm picky.. But damn I just gave up.. Cutting a 5" hole in the bed was a task in itself.. I couldn't find a damn thing in my tools to make the cut.. Finally I had to drill little 1/8" holes in a circle.. Than use a cutting tool to cut it.. Long ........ process..
In the end.. They are in.. I'm not sure if I like them.. It is MUCH louder than I expected.. I assume mainly because they are behind my cab.. Its got this funny drone when you let off the throttle.. Funny, the exhaust is pretty much same setup I had with the old.. 4" System to 6" Tip out the side.. Thinking alot of what I hear is because its behind me now..
However I think they will work tho.. Main reason behind them was the smoke and the noise.. Grant it I love throwing smoke at folks.. But at the same time I don't want to cause an accident nor scare someone into hitting a car because my exhaust is extremely loud at WOT.. Therefore I elected Stacks to get the sound going up instead of right next to someones window with my lift..
They do give one HELLUVA mean look tho
I'll have pics up tomorrow.. I got some installs but no full truck views because I was tired and my battery went dead in my camera.. I'm hitting the sack.. I'm sore as hell..
