- Moderator
- #41
The handle is all that is Hurst, likely not made directly by Hurst for the application. It would be no different than if someone rigged a handle on a 4 speed that has the handle go directly into the trans. The only Hurst shifters that can be adjusted are the side mounts. The have external linkage. A T5 only has the handle and block on the top of the trans, there is no adjusting capability other than changing the throw distance, which is done by changing the pivot location or the handle length.
http://www.jegs.com/i/B-M/130/45070/10002/-1
This may likely be what is in there
http://www.jegs.com/i/Hurst/530/538-0035/10002/-1
This is the adjustable type:
http://www.jegs.com/i/Hurst/530/391-7535/10002/-1
