So it's been 2 years already???
I got some more motivation to continue on this and spent a little bit of time on it this weekend.
I've been looking for an engine wire harness and under-hood accessory wire harness that would be a perfect fit. The actual engine harness is perfect, everything is fine. The harness that powers everything else under the hood isn't perfect. I had to splice the MAF wires which had been cut at the junkyard, and I still need to splice a turn signal on the passenger side, plus this harness doesn't have cruise control wires. Either way, it should get the truck running even though it's not ideal.
I'm trying to remember how the vacuum system madness goes together currently.
