LuCUSS and I spent numnerous years together working on Austins,Hillmans,Triumphs,MG's in the 60's
Sometime I won, somethimes Lucas won
Bronco started to idle really crappy last night, started and idled really crappy this morning...I chalked it up improperly set choke and the temp. At lunch same thing. Pop the hood and some how, it spit the front intake seal...piss me off.
Intake seal? You know that your supposed to trash those and use rtv on both ends.........right?
On a different note, I'm still having rear main seal problems. I installed a brand new rear main seal a little while ago and frickin same thing, rear main seal leak. I'm going to try again at some point and if a 3rd don't work then I'm going to pull my engine and see what the hell is going on. I can't stand leaks and it's driving me crazy.
Is that list from FoMoCo? No, it's not, where Dennis got it, I haven't a clue.Dennis, Bill et.al. what's up with that list? My half of the '75 C700 has got a 361FT 4V. Did they add that in '75? (September of '74)
As for the hipo cd's...you're right, I need to pick them up.
We have something in common Ben, Bill told me earlier on teh other forum that I need to get the hipo cd for the 80-89 Light trucks.
That's probably the 18th time he's told me to get it too. It's only $21 for me. I need to save a dollar a day in a special place, and in 30 days I should have enough for the CD without spending it on something else.
THat image above is from the 73-74 Ford Truck Shop Manuals
I have a few of them
Hadn't needed to do this yet but read about getting 'em cold and that isWell...it looks like ball joints are imminent on the Bronco.
Noticed the front end popping a little yesterday...and a little more today.
And when I headed out to lunch, I noticed the front tires were sitting like this:
l /
Anyway, I think I'll opt for non-greasable moogs. But I have a question on
installing ball joints. Some guys say you need the ball joint press...others
say just freeze and they'll drop in, others say use a block of wood and a BFH.
Opinions???????
