Window problems
The passenger window quit I
  • I tore the door apart I got a -12 volts going down nothing going up
    Then I got no volts up or down cleaned the drivers side switches then got 12 volts up then -12 down hooked the motor still nothing
    Put the probe in and no voltage
    What else can I check
Check for continuity through the motor itself. Also check for good ground. Just having power to the motor isn't enough, you need it to have some where to go.
