winch bumper
i cut down my old bumper yesterday because i was all bent up and ugly. it was a 3 foot piece left and the brackets were bent and the bolts were all messed up so i decided to tear it off and start building a new one thatwill eventually hold a winch.
i want to build it like an old warn winch bumper but it will be 8 inch channel steel for the winch area and 1/4 inch plate evrywhere else. i'm not sure how to do brackets whether i should make like 10 inch pieces that weld straight to the channel steel or
cut two pieces of channel steel that are 4 inches wide weld those on and bolt some brackets on and weld the edges of the brackets then that will bolt to the frame with three bolts.
if my explaining makes no sense i'll put pics up in a bit
