Will AAAA
Mr. Stroker
CASE IH
3,121
67
Michigan
Will a steering column from a 95ish F150 with cruise fit in a 97 F350 with Cruise??!?!?!?!
120
F-series 92-97 steering coloums are all interchangable.
Mr. Stroker
CASE IH
3,121
67
Michigan
Dont think mine has an air bag. Fuse panel has a fuse in the airbag spot tho so idk? I wouldnt even hook the airbag up in a 150 steering wheel any ways. Just want to make sure the cruise control all connects the same between the two wheels.
Do you have a choice not to hook up the airbag? I thought the clockspring housed the electrical connections for everything in the steering wheel. I'm wondering if the connector is different for steering wheels with and without airbags...
surewhynot
Rep whores make me sick
13,843
821
Florida
The steering columns themselves are pieces of cast aluminum cover by plastic and all of the accessories that bolt on. The cast part will accept whatever accessories you have. You can re use the wiring, clockspring, etc. from your old column.
flareside_thunder
7,812
246
Fully interchangeable...a buddy of mine did this same thing.....just disconnect the battery 15 minutes prior to disassembly to be on the safe side...
