Which engine 302 or 352 carb?
1985 Ford F-150
Country Boys Can Survive
7,816
307
Tooele, Utah
If you do have to re ring it use cast piston rings and nothin else. Most machine shops will reccomend moly but they wont seal up and itll burn alot of oil unless it has a near perfect power hone done on the cylinders. Id also check the stroke on the motor your gettin to make sure its really a 390. Just put somethin down a spark plug hole thats long enough it wont get stuck in the cylinder and turn the motor over by hand until it gets to top dead center then mark your dowel or whatever ya used and then turn the motor over till it gets to bottom dead center and mark your dowel. If its 3.5 inches its a 352 or 360, if its 3 and 3/4 its a 390 or 406, if its a hair under 4 inches its a 428 or 410. All these motors use the same block and heads so theres no way to tell em apart from the outside.
1985 Ford F-150
7,816
307
Tooele, Utah
Thats the only way to keep from gettin an advertised 428 when all it really is is a 352 or 360. There are a few other things that you can tell a 428 or 427 apart from the others by just lookin at the outside but theyre so few and far between compared to all the other ones they made.
davbell22602
1967 F100 Project Truck
Who sells cast piston rings for the 390. I couldn't find anything on summit or jegs.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
I found a 390 for 200 bucks or the guy wants me to put the 302(missing intake) in trade for it. He wants the 302 for a mustang. The 390 runs he said someone stole trany out of his truck. Whats the story with the 360/390 burning oil all the time from what I heard.
On sale day, 352/360 engines magically become 390's.
Measure the stroke: 352/360: 3.50" / 390 = 3.78" / 410/428 = 3.98"
1962/74: The Auto-Lite/Motorcraft 2V uses the same carb kit: Passenger Cars/F100/350's/Bronco's & Econolines.
The major difference; The carb jets.
Iron piston rings should be available from NAPA, indie autoparts stores.
If you stick with the 302, you need the power steering pump brackets for the small block. You should be able to use the same pump and hoses, just need the bracket to fit it to the 302. By the way, they look very similar, if I remember right.
