Where is the Mass airflow sensor?
Greg97
Ford Strong
I want to clean the Mass Air Flow sensor and I can't figure out where it's located. I have a 1997 F-250HD 5.8L V8 4X4. Can anyone tell me where it's situated?
I don't immediately know, but it has to be in the incoming air stream. Many times it is bolted to the air box, other times it is in the intake air hose, the final place it can be is attached to the throttle body on the intake.
Greg97
Ford Strong
Thanks Fellro. I disconnected the 2 hoses to the throttle body and no sensor there and on the other end nearest to the air filter and nothing there either. Is it possible I do not have one?
looking at the part, it should be attached to the air box.
getimage.php
436
10
You have to take the round part of the air filter assembly off and pry the inner section out. You will see the wires going into the housing push them gently in to give some slack. Use a flat screw driver to pry the inner piece out. Reach in and unplug the sensor. It has tamper proof torx I believe they are h25 or h27 bits. Use brake clean it MAF cleaner only no carb cleaner it leaves a film.
Thus pic might help
436
10
Do you have a 5.8 or 5.4?? They did make a f250 in both body styles in 97 thru 99 etheir way it should have a MAF and if should be in or in the air cleaner assembly
384
No the only year they had the OBS was 97 and it would be a 5.8.. And not all of those had MAF as they were emmissions exempt and some were.still speed density...
Greg97
Ford Strong
Thanks for everyone's responses! After disconnecting the 2 air hoses I saw there was no MAF sensor on either end. From what I understand it was just after my model year (1997) that they started adding the MAF sensor. The sticker on the inside of my door says it was manufactured in January 97.
jebadiah04
Rooster Snorkler
849
27
He wanted to clean it
Sent from my mudwhistle via lemmiwinks.
^^^ as specified in the very first post... ;)
